Hello, I was just wondering if there was anything to an interface cable for GEN VII to the stock buick harness. Is it just a wiring & connector task or is it there actually to convert somethings to the buick style sensors? My main concerns are with the cam sensor, crank sensor, and ignition module. I know in the GEN VII setup, you can select the style of ignition to the buick DIS system, but can it be directly wired into the ECU or is there an appropriate conversion....
Where can i get ahold of one of these things (interface cable)?
Phil
Phil
