Interior Fuse Panel Question
VinsGN
Its "In Stock"
Most likely a stupid question but would like some clarification.
The fuse panel under the dash, in the interior, (87 GN) has three ignition power terminals to run accessories. For example Scanmaster and/or Tach. My question is are these ignitions terminals in the panel fused or are they hot leads straight from the battery thus requiring an in line fuse?
Thank you for your time.
They are fused, IGN1's are on the STBLT/ACC fuse.
IGN3 is on the A/C fuse.
That being said all accessory wiring should also be fused.
For a scanmaster and a tach. you could add them on one fused wire with say a 3A-5A fuse on it.
NAPA 784802 is the pigtail plug in IGN terminals that make wiring easy.
