I hate to post another troubleshooting question, but here goes.
My TTA will intermittently run rough if it sits for several weeks. I've dealt with this issue for a couple years. All of my garage spaces are full and the car has been parked outside for several weeks without being driven (and it's been rainy a lot this year). I recently started it up to drive it, and the "stumble" is back. Before parking it, I had been daily driving the car 60-70 miles a day and the car ran perfectly.
In the past I've fixed it by changing plugs. Most of the time that fixes it, but there is no reason I can think of that the plugs would foul just from setting for a few weeks.
This time I Ohmed the coils and wires, all of that looked good. I used Deoxit on the plugs, coil, wires, ignition module harness, injectors, injector harness. That made the problem disappear almost entirely. I actually thought it was "right", but it is still occasionally bucking/running rough.
The weird thing is that it typically seems to clear up and run smoother if you roll into the throttle. It seems very random, but not an issue that makes the car undriveable or triggers any malfunction codes.
The common denominators seem to be humidity, not being driven, and/or a few thousand miles on the spark plugs.
Has anyone else had this issue before?
