Ok so we're up and running,she starts up after a while,not sure if I'm getting fuel vapourising in the lines as it takes about 5secs of cranking before the engine fires. The engine runs up in auto choke ok but then starts to knock intermittenly. Sounds like hitting an iron fence with a wooden stick,only does it for a few seconds at a time. I've also got the check engine light dim,and only on when the knock is there. Any ideas please as to where to start?
on a seperate note I've got a pm,but when i try to read it I'm told that admin has disabled private messaging.
