I've never used a jack....easy to just muscle it down and back up..although the "down" part is easier than the "up" part...lol.
1) Get tank as low as possible....drive gas out or drain thru the fuel rail
2) I drive rear wheels onto 2X8's (1.5") high just to raise the car a little so I can get my fat self under. May not be necessary for you
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
_
3) Remove nuts (2) from hangers near bumper. Leave bolts in place. Also disconnect electic connection near bumper on drivers side.
4) Get something 3-6" thick under the car so that you can lower tank onto it in next step. (Boards, carboard box, etc)R
5) Remove bolts (2) from rear straps and lower tank onto the 3-6" thing you have under the car. Note where the spacers are...to prevent spending about an hour trying to put them back in the wrong place....like I did!!
6) Remove the bolts from the front of the car and drop tank rest of the way onto the 3-6" thing. Kinda laying under the bumper at this step.
7) Remove the fuel lines (3)...supply, return and vent. Laying under the bumper here...looking toward front of the car.
8) Drop tank fully down and remove from under car.
9) Clean loose stuff from top of tank/hanger area, tap the retainer ring CW (or CCW I forget) to release hanger from tank. Periodically clean with a vaccum. Do a GOOD job cleaning...anything left loose will probably fall into tank. Once the ring is loose you can gently lift pump hanger from tank (might have to break it loose from the o-ring)...you'll have to twist and angle it a bit as you lift it to clear the float and sock.
Shouldn't take more than an hour to get to this point...
Regards, Bob Kolhouse
