shift quality or lack of it is based on calibration.if someone has installed a larger servo or modified the circuitry or you have a stuck or damaged accumulator piston,spring or accumulator valve in the valve body this can give the same complaint.has the transmission been worked on?if it is bothering you you will need to find the malfunctioning part and repair it after performaing some tests.
