That all depends. Is there any in and out movement in the shaft. I've seen a dirty air filter pull oil like that. A bad or stopped up drain line can cause the same thing, but usually on both sides. In other words there would be a smoking issue though the exhaust also. If there's no oil smoke clean everything
Including the Intercooler. Then clean the air filter or replace it. Drive it like you always would for 100 miles or so. Be sure to listen for a normal noise. If your still getting oil past the seal ring contact Bison or any other reputable company for a rebuild. Hope this helps. I can't tell, but if your running a
stock inlet bell with the factory hose from the valve cover that looks about normal. If there is oil in the DP like you said check the oil drain back tube. They can get full of sludge over time. I've seen crazy high oil pressure
cause this also, but not so much on LC2s.
