I pulled the motor out of my 86 T-Type today to replace the head gaskets. I have this to report so far. I rebuilt the motor about 12,000 miles ago and installed a Modern Muscle Car 206/206 cam, lifters, and springs. When I assembled the motor the lifter preload was set at .030. These lifters have been bleeding down for some time and clack upon cold start up until the motor has oil pressure. I thought that the cam was going bad. The front four lifters on each side of the motor show wear. It is like the hardening on the bottom of the lifters has worn away except for a very small ring around the outside. The centers of the worn lifters are just starting to pit. The rear two lifters on each side look good. My question is -- do you guys think I can install new lifters on this cam and it will be OK??
