Is There A Canned Spray Paint That Matches Engine Bay?
~JM~
Wrinkled Member
I would like to re-paint the radiator hold down plate.
Is there a spray paint that will match (or be real close) the original engine bay color?
If so, what brand & color of paint should I use?
Thank you
From my experience semi-gloss krylon works well. I just spotted in a few areas on a project 87 I'm working on.
I like Duplicolor Engine Enamel with Ceramic. It's been a few years so I forget if I used the semigloss black or low gloss black on the 2 hard vacuum lines that go to the PCV and MAP but it was a good match to the other hard lines that were factory painted.
Thanks everyone. I appreciate the information.
I'm familiar with the Dupli-Color Ceramic Engine Paint. I used that with good results on my last build.
I'll look into the Eastwood offerings along with the others.
