Is there a relay the AC runs off?
87gn-newbee
Car is at a AC shop to get it working. They vacumed it out charged it but the compresser is not comming on. Is there a relay if so where? Any other ideas need them "QUICK" Thanks
Dan
Yes, there's a relay, it's located towards the back of the passenger fender. It's the front most relay.
Assuming that all vehicle fuses are good, jumper the lead for the low pressure switch located on the drier and place the A/C switch to MAX. If the compressor engages, the problem is in the low pressure switch. The low pressure switch can be changed out without discharging the system because there is a schrader valve in the drier.
I found it, the relay a pressure switch were bad now I have ice cold air. Thanks
Dan
