I've been having trouble with what I wanted to do and what should be done either first, last, or not at all. My goals are probably no more then 500 horse power or in the mid to low 11's. Will drive 3 times a week. Some out of town driving, 1 or 2 times a month to the track if I have the time to. Really don't want to stop using E85, don't want to use alky or go with a bigger turbo since it is new already, like to stay around 22# boost, (might go little higher boost, just don't want to get close to head gaskets blowing). Want the car to keep the respect that people have for Grand Nationals. Engine has been rebuilt back to all stock, only has 1800 miles on it.
I have about $3000 to spend and no matter what I have to get a new converter. I just got a new stage one transmission and when I took out the converter I found out it is not the D5. It has 6's or 9's stamped all around it and has a GM15 H stamped on one side and 6399 stamped on the other. Never did seem to stall, but never had a stall before so I wouldn't really know what to look for. Did have bad turbo lag, I think my 60' time was around 2.5 or so. Found PTC 10" 2800 LU for close to $600. Look at my signature for what I have as of now.
Here is what I decided to go with:
Champion iron heads
Revolution X roller cam kit (either the 206/210 or the 210/215 both with .516 lift, would like some help picking cam)
1.55 roller rockers (don't know what brand yet or can the stock ones work with the lift)
PTC 10" 2800 LU
The other stuff I was wanting to get are:
Power logger
High performance coil w/ 8.8 wires
Bigger intercooler
Champion stock ported intake
Power plate
Bigger throttle body
Heavy duty actuator
Air bag
Pinion snubber
The reason I decided to go with the heads and cam first is since the engine is out anyways, that would be the easiest thing to do because I can buy all the other stuff little at a time and won't have to tear down the engine while its in the car.
Unless everyone thinks my goals can be reached without the heads, cam or both, then I can spend money on other stuff to help out. I know that I can have my heads and intake ported, but I don't really know or trust anyone that can do it or atleast do it right. Don't even know what that would cost to have done.
So if anyone could please chime in and give me your thoughts on what should be the best route and what they think I can achieve with the parts and how close I'am to my goals. Thanks.
Champion iron heads
PTC 10" 2800 LU
Power logger
Bigger intercooler
Power plate
Heavy duty actuator
Air bag
Pinion snubber
