Is this too much
84wh1
pimp romeo
Hey guys, i'v got my fuel pressure set at about 40 psi right now. Is that too much for my current setup? Thanks for the help
What do the o2's look like?? I'd say on a stock intake hotair there is little need to run over 32lbs - without a scantool I would be carefull. Check and read your plugs, they show the big picture.
Jeremy
It depends on what octane fuel you are running and how much boost you are runnin
I run 94 octaine and 17 psi of boost. I have no scan tool but could use one if I really needed to.
