X 102 on Earl Brown! He's very reasonable / inexpensively priced and his 3.5" pipe fits perfectly (even with larger up pipe)! I know may sound cliche, but, the angle of the dangle really does matter (difference between a 5-10 minute install or a 2.5 hours install)! Cause some manufacturers pipes just are not bent right (and that's no bull there)! And he sends you everything you need to make it happen too. And it's all quality stuff too (which is another thing you have to be very careful of too)!
Put it like this I have what is basically a brand new MAF pipe (from another popular vendor who will remain nameless), that I took off my car after only fifty miles due to fitment issues and the quality of the connectors. In that, my top adapter connector sucked down so hard that it moved the pipe. (AND IT IS NOT LIKE MY CAR WAS SET ON HIGH BOOST LEVELS AT THE TIME AS IT WAS ONLY LIKE 15 PSI). And while I had no idea this had happened, but, when the pipe moved (from the connector collapsing) it pushed the top radiator hose into the fan belt. Which then cost me my first ever power tour! As i live in the sticks and this happened at 10:30 at night on Sunday night. And u go try and find a top radiator hose for a turbo regal at anytime much less 10:30 at night on Sunday night.
I wouldn't even want to give the pipe away, that I'm telling you about. Even though it's basically brand new. Because I know the results of such! So, please do beware someone else's nightmare out there (when seeking a used MAF pipe)!
If you do buy used, be sure you price Earl brown first. As you might find yourself pleasantly surprised. Also then find out what they have on their car now and why they changed! Because I'm sure that I can't be the only one with a like new MAF pipe sitting around either. And I'm not dogging anyone's product, just relaying my life experience is all! Nightmare is more like it!!
Good luck with it though!!
