It Happened! Blowing water!
buickboy
After a good 7.2 pass last night water started blowing out between the head and block on the pass side rear. 2 steels on each side. Any way to retorque heads and seal it back up or do i need to pull the heads? Experience only, no guesses please.
Mitch
you can try the GM tabs and retorque (back off, torque, heat cycle, repeat) tabs after the retorque.....may work, may not
worked on mine blowing into water jacket
