Jacking points?
Freedster
Hello all!
Anyone have a drawing or good description of the proper jacking/jackstand points on an 87 GN? Hate to break something.
- Freed
You will notice the factor jack has a "dome" on it, and there are several places on the frame where this dome will fit into. This helps stop the jack from slipping
It also makes jacking the car up faster. Just find the holes and up it goes.
The 2 big holes at the front and rear of the doors in the frame are where the body mounts go in, and where the frame is boxed. I go under the crossmember in the front if only lifting the front.
