With Alan's car and the GT47-88 I was at full power at 1.2 seconds......right at the 60' mark. With the 80mm I had it all in at .7 seconds. That doesn't mean I had the ramp in at .7........I had the ramp calling for full pressure at .4 seconds. It ramped from 12psi at launch to 22psi at .7 which was as fast as the motor could physically make that much boost. The issue facing the turbo cars is getting the boost in faster and faster. We are now trying to get the boost higher at launch so that it reaches full boost even sooner. The 330' times you have to run in order to go 4.34 are just under 3 seconds. It's crazy to imagine but if it only takes 2.96 seconds to run to 330', you are at full boost well before that.
Rather than the tire and suspension being the limiting factor, it's shifted back to who can make the most power............or who has the most $$$$
