Joined the 10 second club!
Yes sir Julio!!! Your Kit!
Cheap 93 citgo fuel and pure meth!
On Drag Radials, Stock Suspension.
Same here with the cheap citgo fuel and Julios meth dispenser system, LOL.
I sure wish I would have known that Reynolds had no other gas stations and fueled up before getting there. But now I am educated...
Mike
I just always think its a bit more impressive than when there's 100 bucks worth of race fuel in the tank. ;)
WOOOOOOHOOOOO!!!!!!!! so glad the 10s r now behind and cant wait til the rest of the pieces r put togethr over winter so next year you can join another club...with only 1 digit ;) ;) ;)
How much boost did you leave with? I think i can 10, but im affraid im going to break the drive shaft! I have only left with 2lb's. How much can stock drive shaft, and boxed lower bars handle?
In Reynolds, I was leaving around 10 Lbs. I have stock rear, an aftermarket shaft, but hybrid joints that are smaller than the stock at the DS compared to the yokes. A little strange to me. I will be looking to upgrade to 1350 equipment in the future though.
Mike
Mike
I should have mentioned that I am running a brake also.
Chris,
That was a nice pass, and you have a lot left on the table, I believe. That was a nice 60' time for 2 - 3 PSI of boost. What tires are you running and did you have problems with traction?
Mike
IM on MT ET Drag Radials. 4psi and up and they would break loose.
I only run the 1/8 mile here in NC so can I claim a ten second car with an 1/8 mile run of:
1.535
4.432
6.904
100.04
:D
Hey Julio. Chris ran a high 10's with one nozzle plus I think he said the knob is set to 7?!? Dang!
Walter
Chris,
The Grove kick you out? One run and out?
Last time at the Grove they told me to see tech after a 11.44 run. Tech read off a list of crap, I told the guy "wow that's a long list". :D
Walter.. single nozzle can take cars pretty far..
