Julio can you rebuild my pump
turbo nasty
Turbo Dojo / MNTR
Just wondering if you could rebuild a old pump I have when I replaced it it was leaking from the head.
If I send it to you could you check it and redo it if possible and then ill have a spare.
Thanx
As long as the motor didnt get water in it.
We can get the diaphrams now. Cost of new diaphram, meth valve, and check valve seal basically everything on the top of the pump is like 70.00.
Vs cost of new pump at 150.
If it leaked from the head.. the diaphram and check valve need replacing.. the valve.. may or may not.
HTH
Some more.. its a work in progress..:D
