JUst a few stage ?'s
trading t/a
I'm Angry!!!!!
I know that the TTA heads are undersized for a 3.8 block, but what head could you go to in order to keep the a/c in the TTA? Will the TTA heads support the flow of a good stage combo?(10.0-10.5) They would definately have to be reworked to enlarge the valves and get as close to the water jacket as possible in order to feed that beast.
As I know there isn't a head that will work in conjuction with the f-body platform........
Any thoughts on this.............
If your goals are to run 10.50 to 10.0 your TTA heads ported with a bigger intake valve will be enough. With some good boost that is. :D
