- Dec 15, 2002
Novaderrik, your post implies that you have dropped your tank and inspected the inside ( bottom of it or drained it through a pet **** ) since you started running E85 and have not seen any debris inside, is this the case?? Have you also cut open your fuel filter and fuel sock since running E85?
I did drop my tank and drained it and it had an amount of debris and rust I would consider not acceptable to run through my fuel sock/fuel filter on gas let alone E85. I later got it flushed and the shop confirmed that it was in need of a good cleaning. Garaged since day one.
Do you guys actually check this stuff out or just assume that it's ok because you haven't had any problems? So far it looks like you are recommending actions to others ( like replacing a cheap $15 fuel filter after switching to E85 ) that you yourselves have yet to debunk the myths with your personal findings.
bsdlinux
The above also confirms that you have not yet dropped your tank or cut open your fuel filter since switching to E85. How again is it that you know there is no debris in your tank getting sucked into your fuel sock or fuel filter from E85 to recommend others not worry about the E85 myths with a 21 year old gas tank?
bsdlinux
HTML:
I run 20 gallons a week through my car, no issues. Same fuel filter I was using before I switched.
