When I had a bigger cam I guess this wasnt as much of a problem, OR PROBABLY JUST WASNT AS NOTICEABLE. However, Im currently using a stock block (with stock cam) that is producing more vaccum, and the problem is badddd.
Ive always had a check valve in the system, but it has not been able to do the job lately (this was a brass, ball and spring type that I got from a hydraulic equip. vendor). I took it out and ordered the CV listed on the DIY instructions from GM (part# 14047619) and tried it this morning. No difference. I was driving to work and around town barely able to accelerate, choking (gagging) on alky and water.
This shouldnt be such an issue. Should I try putting two of the GM CVs in line? If so, back to back between the tank and pump, or one after the pump? There has got to be a sure fix for this that will stop the engine from pulling the fluid out on its own, but still allow the fluid to move forward without slowing it down (no road block) when the pump is activated.
P.S. my pump [obviously] has no built in CV. It is a F150 pump.
