Just got my injectors...any tips besides gnttype.org on how to install?
d0n_3d
Boost is good.
I just received my 50 lb/hr injectors today FINALLY and I am so excited to get these things in and get the boost turned up. There is a thing on gnttype.org on how to install injectors but are there any other tips I should follow? Is it pretty easy to do this?
That looks like the instructions that a friend and I used on his car the first time we did it. Just take your time, it's pretty easy.
Very Easy, just make sure you use the new orings, and put alittle vasoline on them to get them in easier.
I echo what the other guys have said...took about 2 anal retentive hours the first time I did mine (blue tops), and about 45 minutes the second time (50's). So you are ahead of the game going directly to 50's :)
I would use a paper towel tip to clean and dry out the openings that the injector o-rings go into...then add a small bit of vaseline (Q-tip) to the inside of these fittings and to the outside of the o-rings prior to installation.
I just followed the gnttype instructions...what a great resource :)
Bob
Be careful with the little clips that hold the wires on the injectors...they break easily. Put all the injectors in the fuel rail and insert the whole thing into the intake. Dont put them in the intake and try to push the fuel rail on top. Its supposed to be much easier.
Be careful with the injector wiring. Heat can make things brittle. Be certain that when you pull the injectors, the O-rings come out cleanly with them. If they tear apart, make certain parts of the O-rings do not end up inside the injector rail or intake manifold.
