Just bought tta #343..I really dont know anything about these cars so ill go over somestuff i noticed about it.........
1st..little bit of rough idle..Injectors have a green stripe on them and chip is prob.original..{says delco on it}
2nd..vac.lines are off wastegate selenoid and a valve is attached to vac.line{valve is open on other side..No line attached}
3rd..car is boosting @20psi..Nothing shows on knock guage..{dont even know if it works..But didnt hear any ping or noise}
4th..i would like to put a in car boost controller in car..Anyone know of a good one to use..or should i put the vac..back on the wastegate sel...and adjust the rod on the wastegate?it looks threaded and adjustable.
5th..can someone tell me where to find a diagram of the turbo vac.lines
Sorry about the long post but i dont want this thing to blow up..LOL..not sure if that boost is too high or not..Also I am ordering a thrasher 92 chip for it..Maybe will help idle a bit..Car also has diffrent downpipe,test pipe,dump,adj.fuel press reg,k&n filter...Thanks For looking..And will appreciate any help offered..Shawn.
