K&N and MAF Sensor, etc...
Bird of Prey
Hi
I'm a bit worried, if the open K&N Filter will work together well with the MAF Sensor? Does the engine run as well as with the stock filter system? airflow?
my first mods will be:
adjustable wastegate actuator
adjustable fuel PSI regulator
8" K&N cone air filter
i think this is okay.
when i go up to 22 psi boost, is it bad for engine components? what would you recommend? i dont want to change a lot of engine parts, i like it stock. but a few mods have to be done. it's a tta!! :D
i want to run 12's
further information highly appreciated!
thx
matt
First mod if you plan on increasing boost is a scantool.
You have lots of reading to do.
