realspartan
- Dec 14, 2008
Hi guys,
For my information, what is the difference between a Kenne Bell 9006u chip and a 9006u3 chip? I used a 9006u3 then switched to a Turbotweak. The Turbotweak definitely gives better idle, smoothness and driveability but I feel the Kenne Bell chip gave me more power and performance at full throttle. It seems like there was more boost at higher speeds/gears as well. My car is all stock except for an original hollowed out catalytic converter, Bosch 237 fuel pressure regulator, fuel pump hot wire, 160 thermostat, and no screens in the MAF. I always run 94 octane fuel with some octane boost here and there for extra insurance.
If I switched back to the Kenne Bell chip would it have any adverse effects in the long run? In other words is the Kenne Bell chip to aggresive? Does the Kenne Bell chip actually produce more power than the Turbotweak or am I mistaken?
I basically want the best possible plug and play chip for maximum power without using a scanmaster to adjust anything and so on.
Any comments?
Regards,
Realspartan
Any comments?
Regards,
Realspartan
