Kenwood Stereo & Power Antenna
TurboJunky
Fire the Federal Gov't
Will the standard power antenna work with an aftermarket Kenwood stereo? If so, how?
According to: http://www.gnttype.org/techarea/images/wiring_images/4_speaker_stereo.jpg
The power antenna connection is the pink or yellow wire in position E of the 4 pin power connector. It should go to what some call the system control terminal on aftermarket radios & amps, the wire that turns on the amps, etc. On my Pioneer it is blue/white, dunno on Kenwoods. The antenna should operate like it does with the stock radio. :)
David
Excellent...I'll print this off for my audio shop. They had a bear of a time trying to figure out how to get it to work properly and it still isn't hooked up right.
Thanks!!
One more thing that doesn't seem to make sense....
The installer found a 3 wire group the he found controlled the power antenna. That make sense??
