THERE IS NO CORE CHARGE ON THIS TRANSMISSION.TWO UNITS.HEAVY DUTY STOCK REBUILT 2004R TRANSMISSIONS.INCLUDES A RESTALLED D5 CONVERTER .$999.00.YOU PAY THE SHIPPING
This high quality rebuilt 2004R transmission is for stock/slightly modified engines.It may be used for turbo Buick applications with stock 231 cid engine and turbocharger and Monte Carlo SS applications with stock 305 cid engine .The transmission is assembled with all new clutches,steels,Alto red racing band,bushings,thrust washers,gaskets,seals,sealing rings,heat treated stator tube, heat treated sun gear shell,Buick Grand National intermediate servo assembly.steel pump rings and all the components included in our SHIFT RECALIBRATION KIT #24RSRKA.There is no warrantee coverage on the forward drum or input shaft.This is the same type of unit others sell as a strip trans .look over the components.
