"Tools/parts Needed;
Small Piece (6") Of At Least 16 Ga Wire
3m T Tap (blue)
Male Spade Connector (blue)
Small Ring Terminal (blue)
Test Light/ohm Meter
Electronics Cleaner
Small Pic
Spray Grease
Good Crimpers
30 Amp Blade Fuse (green)"
But you show a screw too. Was that screw off of the motor, or did we have to supply it. If we have to supply it, what size it it? Length and thread.
"The Jump Lead Will Now Connect To The Wire (in My Vans Case,blue.)" What about in
our case?
"(one Wire Will Show Negative,and The Other Will Show Positive Going Up.)" How does these wires "show" negative and positive? Is it written on them? Does it only show positive as it's "going up"? I ask all of this stuff because this is what's going to happen to me when I rip my door apart, and I don't really want my car sitting torn to pieces for 2 weeks because that's how long it took me to figure it all out. I need all the answers before I engage in this endeavor.
Also, how do we clean and tighten the terminals on the plug? What do you recommend?
"(the CB will keep trying to reconnect voltage) now instead,the fuse will blow and you'll know to check the system." Ok so now what if the fuse blows. I gotta yank all this stuff apart and replace the fuse? What if I don't put a fuse in there?
"and I'm willing to bet if i went and replaced this motor with a brand new delco,it wouldn't keep up
" Keep up with what? Are you meaning the newer ones are slower than the older ones?
Thanks for all your help.
