- May 25, 2001
I installed my billet adjustable fuel pressure regulator earlier today, then took the car out for a test drive. At WOT I was getting near 10* KR through 1st and 2nd. I raised the fuel pressure and got the same thing through 2 more test runs. (Fuel pressure was set from 40 to 50psi at idle. My fuel pressure gauge reads about 5psi high.) At idle, the O2 millivolts stayed between 400 and 500, I thought they should fluctuate a lot more. TPS and IAC are set correctly, I was running 17 psi for the 1st and 3rd runs, 15 psi for the second run. (Second run the knock was closer to 6*.) Is it possible that my O2 sensor went bad? Thanks in advance for any help.
