Knock and boost Question
Justa231
At the track, I can turn up the boost to 25 lbs with race gas and I do not get any knock.
If I leave the boost level at 25 lbs and use 94 octane gas, I get knock at 10 lbs of boost. I do not dare beat on the car leaving the boost at 25 lbs without any race gas.
Does this make sense?
Why do I get knock at 10 lbs of boost when the boost is set at 25 lbs, but when I turn it down to about 20 or 21 lbs with 94 octance, I don't get any knock? (alky)
Does the turbo act differently at 10 lbs of boost when the max is set at 25 lbs compared to 20 lbs?
Nick
Because the race gas is giving you more octane. The Alky is probably bringing your octane to about 105-110, while the race gas is at 115.
This is normal.
You cant expect to drive around at race boost levels without race gas
I was just wondering if 10lbs of boost when it's set at a max of 25lbs is the same with a max of 20lbs.
In other words, does the turbo push the same amount of air at 10lbs no matter what the max is set at?
