JDSfastGN
- Jun 16, 2001
Alright, I just got my motor back in and everything is running great. Well tonight I was on the beltway cruising at 60 or so and decided to slowly get into the throttle. Only about 1/4 throttle, and 7 psi. Well I saw 1-7 degrees of knock. I've never had knock before and I know it isn't false because, if it was something loose, I'm sure it would read knock when it shifts into 2nd or 3rd since they hit very hard. The only things that I can think of were that I had my heads ported and polished with the bigger valves and I installed a powerplate. I did drill the EGR hole. But from what I understood the EGR passage in the heads is now smaller after I got my heads done (does this sound right?) My coolant temp was 165 at the time and my fuel pressure is at 45 with the line off. I am going to change my fuel filter on friday. Since I had the motor out and the fuel lines were open could, the open fuel lines cause the fuel that was in there to somehow clog the filter? Or is my boost just coming too soon and the chip isn't putting in enough fuel. This is my 87 below so if anybody has any ideas, that would be great.
