turboaddict2
- Apr 11, 2002
Was doing some testing today on the parkway. I always got on it on a 4th gear roll from like 65 mph. I have the alky at 7 and have it turn on early like 10-11 lbs. When I got on it there was always transitional knock(first orange light on knock gauge) and then it would go away and then 3 seconds later knock went up to the second or third orange light and thats when I knew it was real knock and let off immediately
. I think I was running 19 or 20 lbs. in 4th gear. Scanmaster counts were 800 o2's and 2.6 degrees at 65-75 mph. EGT's were at 1481. I let off at 100 mph. How can I get rid of the top end knock? Should I just turn up the pump speed to max? I want to change one thing at a time.
Using a PTE alky chip that has 22(or 23) degrees of timing and 100% duty cycle at WOT. Fuel pressure is set at 42 line off. Any help is appreciated.
