Knock knock, its detenation any one there???
psycho6cyl
Ponies Are For Lil Girls
Car will show knock after 10 psi and sometuimes when i let my foot off gs on boost.. Where to go what to look for???
Are you leaning out at 10 psi? or over rich?
Scan tool numbers?
You should see a little when starting up.
We need some 02 numbers.
dan
Knock
im a lil afraiud to run it up there again i dont wanna blow head gasket.. w hat else should i look for
What is your fuel pressure set at? (idle)
What kind and how old is the fuel in the car?
How old are the plugs?
You would be detonating because of a lean condition or sometimes over-rich. Most likely lean.
Without 02 numbers it is hard to tell.
Do you have a scan-tool?
