got this new T type and having a hard time tunning the thing, the car had a variable timing chip in addition to a three bar map put under the dash to aid with the boost feedback, weird set up but anyways, part throttle gets lots of knock this car makes boost like mad, 1/4 throttle and boost is up at 16psi and knocking like crazy, with the propain on at 50% still knocks hard, the knock goes away for a couple of frames but it comes right back at WOT big time , I noticed the downpipe is hitting the frame but that would cause false knock not real knock, the engine was assemble with a single steel shimm gasket which bring compression to around 9 to1 which means running 15 psi on this motor is like running close to 19 psi, but still with 91 pump and propain on the knock should not even be existent. I have direct scan hooked up in the car with the old chip it was showing way lean thus causing the major knock, so i took off the 3 bar map and hook had a new chip put in, still getting knock at part throttle but now its running way rich, around 850's or 870's on the 02's or should I say around 9 to 1 and 10 to 1. what is going on, should i be looking at something else on this thing, is driving me nuts.. btw the car has a caspers fuel pump in tank that is hotwire from the relay on 3 bar map at the fender on the car, fuel pressure holds good , 13.7 volts from the alternator so that is also good, any ideas feel free the chimme in... also has ported heads/intake/ stock ported turbo and inlet, so this things flows air like mad and that explains the spool being so quick at part throttle..
should the car be going on open loop at WOT or CLOSE loop, i noticed that it stays at close loop no matter what weather it be wot or at idle, only time when its open its at initial start up ..
