You need an aftermarket chip for adjust ability. I recommend the extender chip so you can adjust WOT fuel with the WOT fuel knob on the Translator. You also need to know fuel pressure.It has an engine rebuild from the origianal owner, it has about 20k in rebuild. He did new cam, I dont know the specs, Injectors, also didn't document what size they are. cam bearings, Forged JE pistons .020 overbore, rod bearings, main bearings, head gaskets, and a ton of other stuff. I have done an LS1 maf with a cold air intake, Top end cleanup TB and plenum, fluids change, the chip is stock.
