Nov 17, 2002 #1 6 6SENSE Member Joined Jun 3, 2001 Messages 1,635 What is recommended amount of tourque when installing? I was thinking of checking mine. Dont remember if I had tourqued it down when I put it on, or just tightened it down.
Nov 20, 2002 #2 K kh440 Jo Bu needs a refill! Joined Feb 14, 2002 Messages 3,968 There isn't an actual torque spec on it and the sensor doesn't seat in a water or oil passage, so hand tighten should be fine.
Nov 20, 2002 #3 b4black Well-Known Member Joined May 24, 2001 Messages 3,776 NNNOOOOO!!!!! Over tighten - too senstive (bye-bye timing) Under tighten - not sensitive enough (bye-bye head gasket!) I think it's 13 or 14 ft/lbs. I'll have too check. ....try this: http://www.turbobuick.com/forums/showthread.php?s=&threadid=57181&highlight=knock+torque
Nov 20, 2002 #4 6 6SENSE Member Joined Jun 3, 2001 Messages 1,635 Thats what I was thinking, I remember hearing about them being too sensitive and want to check and make sure mine is in their right.
Nov 20, 2002 #5 b4black Well-Known Member Joined May 24, 2001 Messages 3,776 and no selaer/tape on the threads.
Nov 20, 2002 #6 K kh440 Jo Bu needs a refill! Joined Feb 14, 2002 Messages 3,968 Damn.....guess you really do learn something new everyday.....
