richardv6
- May 11, 2007
running alky razor kit with fast.when i floor it wot the audible knock sensor goes off, then if i get back into it easily it will not.i am running 110 octain and alky on 6 also running double fuel pumps 2nd comes on at 10 psi. think it is being flooded at first causing knock,should i turn up 2nd pump cut on time more say 19psi.any ideas be helpful.i always hit test button before i get on it.
