knock
kevin
i'm getting knock when i let off the gas.it happens as i ease off the gas.i think its the alky still going in motor.i have the razor dual alky.has anyone else had this prob?
I bet its the motor moving around cuasing the sensor to go off. The 3 bar MAP shuts the kit off when you lift, the throttleblade is also closed, if any alky was still in to lines it would be miniscule, and not enough to cuase a knock condition.
Turn the boost down and shut the alky kit OFF. Then run the engine see if your knock goes away. If it does, switch the kit on.. run the same boost and see if it knocks when you lift. Report back.
