Largest turbo under a stock shield
The problem isn't the turbo itself, but the downpipe elbow, if you are talking about using an unmodified turbo shield.
Do you mean a stock shield cut for a THDP?
Or the largest turbo that can use a stock elbow, or an elbow that will fit under a stock shield?
I have asked this a million times and still don't know. I know the DP is an issue but not a problem you just trim it. But will it fit around what size turbo. I have a 76
Any t3/t4 turbo will fit under the shield. If the elbow isn't used you will need to alter the shield
