launch technique
gnboostmex
fast class
what is the best launch technique.
I could not create much boost for the launch. some tip
que tal amigos consejos para un arranque mejor.
What usually works for me is to lock the emergency brake and the foot brake, then attempt a brake torque. You'll either spool enough boost to start overpowering the brakes or it will uncover the fact that there might be another issue preventing high boost launches.
you say you couldnt create much boost. how much boost were you able to get?
I have tried some techniques the rims up Ebrake 8psi slows
foot brake to 6 psi
the Alky begins 5psi
this matter or do I have any problem with my vacuum brakes:confused:
I can't get more than 5lbs with stock converter on foot brake. Car stays put though. I'm trying a new converter soon and then I'm sure it'll overcome the brakes.
