t3intercooled
- Jul 20, 2004
Does anyone know where a good spot to route the wires from the wideband to the inside of the car Via the passenger side?
SignUp Now!There is a large grommet underneath the A/C box on the firewall, that the HVAC vacuum tubes run through, I drill a hole in that everytime I install an alky kit, and it has plenty of room, for whatever wires you want to run through it.
It's easier to see the grommet from the inside of the car, move the ecm, it's near that on the firewall. I usually drill a hole in that grommet from the inside, then route something like coathanger through the hole, it'll hit the inner fender and then go up, then you should be able to see it under the hood. Tape the wires to it, then pull it back into the car along with the wires.
Great pix! Much easier to tell you with those, it's the grommet on the bottom (of your post, with the fewest wires) I usually go through the right side of the grommet. Just drill a hole right there, and I usually use a very heavy gauge stiff wire to push through that and it'll run along the inner fender, then you should be able to see it around where the relays are.
Where did you end up purchasing the wideband? Been wanting to get one of those to help with the tune on mine...
