Sorry for the lame post but... how do you perform a leakdown test ? I'm a little curious/nervous that I have a headgasket problem.
When I start my car, I notice white steamy smoke coming from the pipes. It doesnt smell like coolant, more of a rich smell. After the car is good and warmed up the smoke is gone. I checked the oil and it is clean, although it has a slight gassy smell. The coolant also looks fine.
I am going to run a compression test on the cylinders but am not really sure how to perform a leakdowwn test..
Couple other notes...
If the car sits and idles for a while there will be some small puddles of condensation under the pipes
I first really noticed the smoke after putting the hooker cat back (test pipe) on. Could I be burning the oils off of the pipes ? They were slimy as hell out of the box.
