If it leaks, its not becuase of methanol. The way the pump is setup can play a role whether it can have an issue. Example is cranking down on the pressure screw and having it activate/deactivate the switch when it hits pressure over time can cuase the seal to tear. Alcohol or not.
As far as internals, that varies with model.
Contact who you bought the pump from for assistance with sealing it.
