Goodmorning guys,
I noticed last night that my gn was leaking a little brake fluid from the brake switch. It took a little of the paint off on the bracket that holds up the brake motor. No big deal. I will take it out and repaint everything. Anyhow, when i added the new switch, i did the 15 brake presses with the key off, took the old one out and then added new one and tighten. In the beginning there was no leak, but noticed after a few drives with the gn. Do i need to tighten more or take it off, maybe use teflon or something simular to seal?
Please respond and thank you
Michael
Michael
