Leather 02 Grand prix seats-modified for gbody
Verz
Build'n it Better
So doesnt look like car is going to sell with these in it.
Seats are from a 02 grand prix gt 4dr. Seats are a dark graphite color with the driver side being heated and power controls. The grand prix seat tracks will be included for both front switch as well as the heated seat switch. Seats are in great comdition other than a 2 inch tear is driver seat bolster. Fronts will bolt up to stock regal sliding brackets and rear modded to clear Trans tunnel and rear fender wells. Asking $250obo for front/rear seats both seat trackers w/ driver being power and heated seat switch. Located in Wichita, KS, will not ship but can meet in reasonable distance.
Call/text Aaron 316 644 7446
Pics as installed
Seat brackets mounted
so you bolted the seats to a set of Regal manual slider brackets? any other mods to make them fit?
what was done to the rear seats to make them fit?
Car sold with the seats on wed so these are no longer for sale. Thank you for all the compliments, took some work but turned out great for little money and that console should look familiar as its out of a ls1 Trans am
I still would like to answer your question. Yes they are mounted to manual sliders, luckily the front to back dist is spot onbut the mounting holes on the seat bottom are too wide. Just drilled holes inboard about 3/4in and used grade 8 bolts to attach sliders and bolt to stock regal mounting points on floor. Rear seat bottom cushion needs some foam cut oit to clear driveshaft tunnel(real easy) abd than pull back the leather cover at each rear corner and cut out a section of the seat.frame thats about 3x3 so itll clear the wheel wells. Seat back just needed the mounting points cut off, used a couple metal straps with bolts through rear panel to hold upper portion back and bolts in rear bottom to hold that in place. If I had to do it all over can prolly get it done in 3-4hrs tops.
