fastblackracing
- Apr 7, 2009
I recently got my car up and running and spent a few hours at the dyno getting some driveability issues sorted out and some power pulls worked on. We ran out of time and will get back on it next spring. We ended up at 680 hp at 30# with 19 degrees timing on a mustang dyno. The compression on this engine is 8.2 to 1. I feel that there is probly another 40 HP or so left in this combo when we get back to it. My question is what would raising the compression another 1 to 1.5 points be worth power wise? Once the combo is maxed out, how much would you lower the boost and raise the compression to be power ahead? 3# less boost 1 point more compression = more power? Does any one have an idea? Is the answer to this related to back pressure in the turbo, what should I be looking for on the back pressure, a certain number, a ratio to boost pressure, a sharp rise in the backpressure curve? How much would timing change with more compression? Right now the power peaks at 6200 and is pretty flat from 6000-6500. Little engine 233 inch needs more power pulses higher rpm, I may have to change my rear gear to make it work. Sorry this is kinda long whinded but I am able to start gathering stuff for my next engine right now and am and looking to be more purpose built. The next one will be in 260 to 278 inch range. Fuel is c-16 and I will be staying with a 3 bolt housing most likely. Just thinking outside the box and trying to learn. Thanks, Mannie
