lee thompson headers
crazygn
10's here i come
Does any one run these headers , do you like them , how about the 3" down pipe that he made and the high flow cross over with the deltagate on the cross over. How does this work , i guess you wont use the elbow on the turbo and waste gate any more, and the delta gate on the cross over lets off pressure, i guess. Does the down pipe come off the side of the turbo .:confused:
i use them and they're great.
the dp does bolt directly to the side of the turbo,eliminating the elbow.
i had my deltagate plumbed into my test pipe to keep the racket down on my street car.
if you get some i would recommend welding a gusset in the normal spot on the driver's side before you install them.they will crack there like all the rest.lee has done this to his own set too:D.
later,sean
hey wfo how much did the kit cost when you got it, is 600.00 a good deal for it all new
thanks bud:)
if that's everything(headers,x-over pipe,up and down pipes),and it's new that's a pretty good deal.
does it come with a deltagate for the crossover?
