SpeedRacerX
- Jan 20, 2014
Goal: consistent low 11s. Crack off a 10.xx here and there. 85% street. 15% track.
Here's the plan to take the GN to the next level. See anything you would suggest doing differently???
Thank you!
- CASV4 SLIC upgrade to RJC 315-XTF Front Mount.
- Add Spal Dual Fans.
- Change out 42# injectors and chip to 60# flow matched injectors and new chip.
- Swap TA49 turbo for a TA6262 or a TA6266. Garrett .63. PTE CEA style? Journal.
- Swap factory TB/Plenum/Power Plate for 70MM TB/Plenum/Power Plate.
- Have the stock Trans built for 10s.
- Swap stock torque converter for a ProTorque 10" 2600-2800 lockup.
- Add B&M 70264 Trans Cooler.
- Add Hughes HP3880 Deep Trans. Pan.
- Already in place: Alky, 3" downpipe, big air intake, exhaust, dump, valve springs, suspension, bracing, bags if needed, alum. wheels, drag radials, adj. FPR, scan master, etc..
- Run stock MAF till it can't or upgrade to LT1 3" or LS1 3.5" plus Translator.
- Heads stock, exhaust manifolds stock.
Thank you!
