License plate light wiring diagram
Billdogg
PSI FED 6
Does anybody have the wiring diagram that includes the license plate light? Mine is out, and I put a good bulb in, but no light. TIA.
Have you probed the socket for a simple ground and hot?? Are your rear taillights functioning?? I believe they should be on the same line. Check to see if you have 12 volts and a ground... I'm sure those sockets corrode over time too.
After probing for hot and ground as suggested.
The splice for the brown hot wire is located in the right side tail lamps wiring harness inside the plastic loom I believe.
Same with the ground black wire and splice point.
The tails are working fine. I will try that next time I have some time. Thanks guys.
Just to clarify what I meant is the license plate wires tie in with the tail lamp wires in the location I previously mentioned. :)
If the tail lamps work on the right side it (the problem) must be between the splice in the harness and the socket or the bulb itself.
