ever since i rebuilt the motor earlier this year it sounds like a lifter tapping.i even went as far as replacing the lifters again a couple of months ago.and yes i soaked them in oil overnight.the valve springs i put in were single springs with a yellow stripe on them.the original springs were dual spring.my question is would the single springs be too weak?and i'll also add that it's not the exhaust manifold,i checked for that.thanks.
		 Did the lifter from advance thing-4000 miles and lifter went bad and ate lobe. At 90k replaced the springs-rebuilt engine @130k w/replacement cam and lifters-replaced w/comp cam(206)w/matched lifters and no probs so far! But the lifters looked exactle alike except the # on side had a diff letter prefix-they looked identical. Just my 2 cents
